Showing results forĀ
Search instead forĀ
Did you mean:Ā
Management vlan
joseph.steve
Hello
All our  access switches are configured with default vlan IP ( i.e ) Vlan 1 - IP Range 192.168.1.0 255.255.255.0
On applying management vlan IP we dont have access to switches via telnet or ssh
how to secure the user-switch from accessing from default vlan ( vlan 1 )
On 4506 we configured layer2 and layer3 vlan
vlan 1
name user
interface vlan 1
ip address 192.168.1.254 255.255.255.0
vlan 2
name management-vlan
interface vlan 2
ip address 10.1.1.254 255.255.255.0
interface giga 0/1
description connected to switch1
switchport mode trunk
interface giga 0/2
description connected to switch2
interface giga 0/3
description connected to switch3
on 2960 access switch
vtp mode client
vtp domain ICC
vtp password cisco
interface giga 0/0
interface vlan 2
ip address 10.1.1.10 255.255.255.0
line vty 0 4
password cisco
Reza Sharifi
You need to configure" switchport trunk encapsulation dot1q" on your 2960s since you already have it on the 4506.
Also, you need a default Gateway on your 2060 to be reachable for management access.
ip default-gateway 10.1.1.254
Don't use vlan 1 for user or management.  Use a different vlan id.
vlan 2 user
vlan 20 management
