Protected port BUT allow specific MAC
David Kondicz
Hi all,
i have big problem.
We are using catalyst 2960S Lan Base IOS on Radio towers. We just bought 50 Accest points, thas are GPS synchronized. Problem is the APs need to be connected on L2-mac betwen each other. But at this time we are using port isolation on each switch (tower) by protected port function to isolate clients from each other.
My question is, is possible to specifi a Mac addresses in specific vlan thats can comunicate betwen protected ports? On tower is one Master unit and others are slave. I thing there is only 1 dirrection comunication - from master to slave.
Can anyone help me please?
BR
Dave
1ashlee2794
Hi David,
Looks like you can use Vlan access map filtering at the mac level for this...
Wendell..
1ashlee2794
Hi David,
Wendell..
If i specify it by mac, will it alow L3 IP layer too from current MAC address?
Does IP Base on 2960 supports this feature?
Thanx
BR
Dave
