managment ip
aksher
can a 3000 series switch be conf. for management ip using int vlan command.
aijaz802
once u login to the switch thru console goto the "configuration menu", then "IP Configuration menu", here you have option to provide ip address,subnet mask n gateway...
You can configure the mgmt vlan ip as shown below..
interface Vlan1
no shutdown
ip address 10.0.0.1 255.255.255.0
You can check the following link for more information...
http://www.cisco.com.ru/en/US/docs/switches/blades/3020/hardware/installation/guide/HGcliSET.html
http://www.cisco.com/en/US/products/hw/switches/ps633/products_user_guide_chapter09186a008007efa4.html
Pls rate if it helps..
BR
*aijaz*
glen.grant
Yes it can , this is for switch mgt. only and has no routing function .
