Manual Vlan pruning
cisconoobie
Level 7
Level 7
How is this performed ?
ankbhasi
Hi Noobie,
Check this link for Enabling VTP Pruning
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swvtp.htm#wp1072526
Check this link for Changing the Pruning-Eligible List
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swvlan.htm#wp1221846
Ankur
*Pls rate the post if helpfull
glen.grant
Manual pruning is manually pruning off any vlans on a trunk that are not needed , on a IOS switch on each side of the link it would like "switchport trunk allowed vlan xx,xx,xx,xx etc.... instead of just allowing everything across which is good practice.
