many drop packets on vlan interfaces.
jimontoro
hello,
I need help with the following problem. In the show interface vlan below showing thatthere are many packages drops:
Vlan864 is up, line protocol is up
  Hardware is EtherSVI, address is aca0.160b.b240 (bia aca0.160b.b240)
  Description: vlan Clinica1
  Internet address is 10.181.196.1/22
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 12/255, rxload 1/255
  Keepalive not supported
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 9w0d
  Input queue: 0/75/234979/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2906000 bits/sec, 3410 packets/sec
  5 minute output rate 47946000 bits/sec, 6264 packets/sec
  L2 Switched: ucast: 16121442 pkt, 7537891871 bytes - mcast: 7349474 pkt, 955799439 bytes
  L3 in Switched: ucast: 6197943355 pkt, 882633089706 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 32120770166 pkt, 37230386116785 bytes mcast: 0 pkt, 0 bytes
     14544321917 packets input, 1583735924247 bytes, 0 no buffer
     Received 12783465 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 4279 throttles
     32352034906 packets output, 37490641944675 bytes, 0 underruns
     0 output errors, 0 interface resets
Please could you help me with this problem?
thanks in advance
Ton V Engelen
Level 3
Level 3
i m not sure you really have a problem considering the dropped packets.
You have 234979 dropped packets, and a total of 14 billion something packets input.
So not many packets %-wise are dropped considering the total amount of input.
Yet, it is not sure when the packets are dropped.
If i were you i d clear the counters of this interface and check the interface again upcoming days/weeks for drops and input packet and how they relate %-wise.
FI. I also see drops in our network on highly utilized interfaces, but when i do some math its about 0,001 % drops compared to the amount of input packets.  I can live with that.
