MAX- Port monitor Session (more than 2)
rushan_2
I have a network with 4 different types of traffics and I would like to monitor them. I have 4 different Ports connected to different analyzers. Unfortunately I am only able to create 2 monitor sessions on my catalyst 3560G.
Is there any workaround or appliances that I could use to make this happen.
Thank You
Rushan
cisco_lad2004
Level 5
Level 5
One solution would be to to SPAN all traffic but rely on sniffer to filter.
With 2 sessions and 4 streams, you would have to filter 2 streams per sniffer( at sniffer level).
Another solution is to trunk the remaining 2 streams to another switch and run 2 additional session there.
Sam
Thank you SAM.
Hi Rushan
Glad to help !
Please remember to use the rating system if the reply has helped in any way, so other readers can scan through posts and refer to posts if needed.
Sam
Hi Rushan
Glad to help !
Sam
