Maximum number of HSRP groups on 3850
dbrennan_1
Can someone verify the max number of HSRP groups on a 3850 switch?
This guide says 64
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/37e/consolidated_guide/b_37e_consolidated_3850_cg/b_37e_consolidated_3850_cg_chapter_01110110.pdf
7 Replies 7
Reza Sharifi
Thanks for the response.   I'm not looking for group number range on v1 or v2 but rather the actual number of separate HSRP groups that can be configured.  For example on the 3750 the number is 32 instances (limited by hardware).
Has this number been increased on the 3850??
Do you know the command to look for it?
If you do, I can look it up on a 3850 for you.
This guide says 64
Thanks!  That's what I was looking for-missed it during my search.
Glad to help and thanks for the rating!
bergonz
The exact statement for 3.7e was: "You can configure upto 128 groups at the configuration level but the recommended HSRP group number limit is 64."
Such a statement is not present in 16.5 nor in 16.12. I understand that 16 is "newer" than 3, at least according to https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2016/pdf/BRKCRS-3300.pdf
So we still have to find out what you can configure, and what is recommended, in 16.x.
