3850 VRF
ssg14
Level 2
Level 2
Quick one :
How many VRF does 3850 switch support with the IP services license enabled?
Samy
Leo Laohoo
3850 supports VRF-Lite.
 Maximum VRF limit is 26
Multi-VRF CE Configuration Guidelines
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3-2_0_se/routing/configuration_guide/b_rt_32se_3850_cg/b_rt_32se_3850_cg_chapter_010.html#ID6035
The switch supports one global network and up to 26 VRFs.
Sandy
bergonz
Community Member
3850 limits seem to change over time, now it says: "The switch supports one global network and up to 256 VRFs."
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-12/configuration_guide/rtng/b_1612_rtng_3850_cg/configuring_multi_vrf_ce.html
