ME-3600X-TS interface issue
rubberheart
I know it is a very very old devices
we see a very very weird thing in the switch , we try to connect a device to one the of the interface
On the endpoint device side, I can see the interface is up, no issues, but the switch side shows down
we admin-down the interface in switch and we can see dendpoint interface go down
we re-enable that switchport again , even we still see "notconnect" , but in endpoint side , it say up up
we asked DC OPS team test the cable , all good , we tried straight , X-over,, default interfaces , etc ,, even changed another switchport ,, same issue ,, we even changed another endpoint , same result
what could be this issue ? any thought?
many thanks in advance
Hello @rubberheart ,
can you share the output of the following commands for the interface in question:
show run interface gigabit 0/x
show interface gigabit 0/x
show interface gigabit 0/x switchport
show interface gigabit 0/x trunk
show interface gigabit 0/x status
show interface gigabit 0/x status err-disabled
Regards, LG
*** Please Rate All Helpful Responses ***
First, thanks, LG
The interface is defaulted, there is no configuration, and I just "no shut" it
interface still show down, not in erridisable mode as well
GigabitEthernet0/1 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, and the address is 001f.6c8d.1234 (bia 001f.6c8d.1234)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
I understand, but still would like to see the show run interface Gi0/1 command and the rest of the commands that I mentioned. From the output of the show interface Gi0/1 and what you described it looks like a cable issue. This is the reason I would like to see those outputs.
Regards, LG
