Memory card capacity on 2600 series (2691) (under 3700)
John Cheetley
Level 3
Level 3
Placed a formatted (under DOS FAT32) 256 MB Cisco compact flash card in router
on SIMM section
This doesn't appear in the sh file system command or the sh version command
Place a 32 MB compact flash in same SIMM section on MOBO and router reads this via above commands
Unless the 256 MB isnt any good which is weird as  I had just transferred the IOS to this.
Thanks again..:)
PS. Please advise if this is the correct area to post.
7 Replies 7
Jaime Valencia
This is Video Over IP, please move to a relevant area, probably a general routing/ISR area
java
if this helps, please rate
Thanks Mr Valencia for the hint
Sometimes the bootrom limits the size of supported flash on the router. Go to the download section of your device and see if there is a newer bootrom available.
Hi Karsten,
Thanks for the response. As I have found out. Apparently the bootrom is included with the current image I have. I can't understand how Cisco would limit this 2691 MPS router to just a 32 MB compact flash card limit considering the size of the IOS's are above 70mb.
I don't suppose you have other options?
If I remember right, these devices support at least 64 MB of flash. And with 12.4 as the last supported versions, the IOS shouldn't be larger then that.
All in all, when the 2600 routers were introduced (that was last century, wasn't it? ;-) ) 32 MB was not really much, but quite common.
But you are right, these limits are hard to understand. My HO-router is a 866VA. Before loading a new image, I have to delete the old one because the flash is to small for two images ... :-(
I'll have to check this (IOS sizes) and get back to you if I can Karsten.
Hi Karsten,
Cisco 2691 routers support up to 128 MB for compact flash
http://www.cisco.com/c/en/us/products/collateral/routers/3700-series-multiservice-access-routers/product_data_sheet09186a008009203f.html
So now have to purchase this flash. Thanks again
