Memory Leak on 3850
fdharmawan
Level 4
Level 4
Hi Guys,
I recently read a field notice from Cisco regarding memory leak on 3850. Below are the details:
I have several 3850 with 16.3.5b running in my environment. I took sample on 3 of my switches and so far I did not find the symptom explained.
Should I upgrade my switches to a newer version? The severity on the page itself is 'only' moderate.
Thank you.
2 Accepted Solutions
Hi Fdharmawan,
WS-C3850-48P, I would recommend upgrading to IOS-XE Version 16.3.6 as shown below. Here’s the Release Note for the IOS-XE Procedure to upgrade from IOS-XE 3.xE to IOS-XE Denali 16.3.x in Install Mode and have mentioned all known bugs related  memory leak.
(https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/release_notes/ol-16-3-3850.html)
Hope response helpful to you!
BR
Tayyab
*** Please rate all helpful responses and mark solutions***
Leo Laohoo
I know I would.
The firmware you're using is a "re-build".
6 Replies 6
Hi Fdharmawan,
BR
Tayyab
Hi Tayyab,
I guess I will upgrade to 16.3.7 since it is the current recommended IOS.
Hi @fdharmawan
just for your information to read before you go for the upgrade we faced recently production enviorment.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCui54490      (for this bug upgrade to 3.7.4E)
BR
Tayyab
Leo Laohoo
I know I would.
Hi Leo,
Thank you. Will upgrade to 16.3.7.
Cheers.
Glad to help you.
BR
Tayyab
