Meraki switch stacking
stephenstown20
Level 2
Level 2
I have configured 3 x Meraki switch stacks
do I have to use the stacking interfaces/cables ?
the  100 cm  stacking cables are not suitable for how we need to lay the cabinet out
Ambuj M
you have 1 stack with 3 switches of 3 stacks of 3 switches per stack ?
whats the switch model ?
Meraki has a dedicated community, you might get faster answer there https://community.meraki.com/t5/Meraki-Community/ct-p/meraki
-hope this helps-
hello
the model number is MS 225
Ok for stacking you can use one of these part based on how much distance is between switches, if they are in same rack with no space then MA-CBL-40G-50CM, should be fine, you will need 3 of them
MA-CBL-40G-50CM
MA-CBL-40G-1M
MA-CBL-40G-3M
these switches only need 2 post rack.
-hope this helps-
Rich R
Short answer: YES, you must use stacking cables for a switch stack to work.  Without stacking cables it's not a stack it's just individual switches.
Meraki also supports "Virtual Stacking" for the purposes of templated configuration across multiple switches but that does not provide the physical resilience and redundancy that an actual stack with cables provides.
https://meraki.cisco.com/lib/pdf/meraki_whitepaper_stacking.pdf
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
