Merging VRFs
lkadlik
If you merge VRF A with VRF B and VRF C BUT VRF B and C are not merged together can VRF B see the routes/information for VRF C?
Or does VRF B and VRF C ONLY see the information for itself and VRF A?
If you merge a new vrf into an existing one do the routes reconverge for the exissting one ( ie would they notice)?
Lynne
Reza Sharifi
no, uless you do export/import between B and C
correct
What is VRF B and C have the same ip addresses?
Will A be able to distinguish which is which?  Or will there be routing issues between "A and B" and "A and C"?
I am trying to come up with a way to allow a host on VRF A to talk to hosts on multiple other VRFs, each of which has the same IPs in use, but without causing a routing issue and without causing the other VRFs to see each other ( ie I only want communication to work between VRF A and each of the other VRFs individually).
