05-18-2018 03:06 AM - edited 03-08-2019 03:03 PM
Hi All,
I have a requirement to setup MS NLB multicast on a network that has VSS 6509s at the core providing L3 interfaces which connects to two Nexus 9504 switches (layer 2) and then another two Nexus 93108TC switches (layer 2). All inter switch links are VPCs and all nexus switches provide layer 2 switching only, no layer 3.
If I setup static ARP entries on each Vlan interface and static mac address entries pointing to multiple Port-channels (Multicast NLB) on the 6509 switches will this work for MS NLB? Do I need to configure anything on any of the Nexus switches? Will it work as I read that Nexus 9300 switches do not support MS NLB?
I have very limited knowledge of MS NLB so excuse me if I've made any basic errors in my understanding of MS NLB.
Cheers and thanks in advance :-)
Solved! Go to Solution.
05-18-2018 06:38 AM
If the Nexus switches are layer-2 only than you need to configure NLB on the 6500 series.
Have a look this document on how to configure it on the Catalyst series switches.
05-18-2018 06:38 AM
05-18-2018 11:12 AM
Thanks for the link and the advice I'll put it into practise in the next few weeks.
