[Migration approach] C2960X L2-switches stack
DamienTokyo
Hi everyone,
I have been asked to support the migration from a 4-switches stack (WS-C2960S-48LPS-L)  to a new 4-switches stack (WS-C2960X-48LPS-L). We will re-use exacting same place in the rack, exactly same cables and exactly same configuration. These switches are L2 distribution devices mainly connected to user's devices (laptops, IP phones, etc) inside a medium-sized company local network. These switches are also connected to L3 core switches and so on.
I have a good idea of the work-around for this migration, basically re-using previous configuration and cables (connected to some servers and users's laptops). However I am thinking of what kind of checklist I should prepare before migration day.
Here are some ideas I have to make sure everything goes well after migration, for each point I will compare Before and After switches replacement status:
  1. Create a matching list of Interfaces/VLAN/MAC Address/IP Address (show mac address-table, show ip arp)
    => Everything should match before and after except if a laptop is not connected, etc...
  2. Do a "show cdp neighbors" to confirm connected devices
  3. On trunk interfaces (trunk connected to L3 switches): confirm spanning tree status with a "sh spanning-tree int <Interface name>" to confirm status is same as before
My question is, according to your experience, am I missing any other thing to check after migration ?
Damien
16 Replies 16
DamienTokyo
Hi everyone, thanks again for your help. Here is some news about the migration I handled: all went well no issues to report at all. I have been careful with configuration transfer and re-cabling so everything went smooth.
If it can help some people in the future, here is the checklist I have followed (output to save before AND after replacement) to ensure that actions did not have impact.
Best regards,
Damien
#Command / Action to doDeviceConfirmation criteria
1show cdp neighbornew switchsame number of neighbour devices
1bisshow cdp neighborneighbor switchcan see new device connected
2show switch detailnew switchmake sure we get the same neighbor ports
3show spanning-treenew switchsame displayed output as before
4show mac address-tablenew switchroughly same number of client mac addresses
5show ip arpLayer-3 switchroughly same number of matching IP/mac addresses
6show arp allFirewallroughly same number of matching IP/mac addresses
7ping -listLaptoproughly all targeted devices responding to ping request
8On a few seats, check if IP phones are starting and if you can connect your PC to network cablesIP phonesIP phones booting up normally inside office
9Try to connect on internal Wi-Fi + guest Wi-FiCompany Laptop + personal MobilePhoneCan connect back to wi-fi as usual
Thanks for sharing the results of your migration and the check list that you used to verify the results. +5 for that contribution. I am a bit surprised that you did not find the command show interface trunk to be a helpful verification step. Glad that the migration went well.
Rick
