mirror port for web monitoring
tedawson
Can the Expres 500 be configured for the switch port analyzer function ?
mohammedmahmoud
Level 11
Level 11
Hi there,
Catalyst Express 500 ports can be configured for SPAN only by using the Cisco Network Assistant (CNA):
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml#Cat500
HTH, please rate if helps,
Mohammed Mahmoud.
sachinraja
Level 9
Level 9
Hello teda
You can configure SPAN on the Catalyst Express 500 through Cisco Network Assistant 3.0 using the Diagnostics Smartports Port Role. From the Smartports window, simply select the Port Role and the ports for SPAN. Download Cisco Network Assistant 3.0 for free at http://www.cisco.com/go/cna.
Try this and let us know...
Raj
is possible to configure two or more source ports that can be monitored in only one destination diagnostic port (SPAN)
Fabio
