MLS QOS SRR-queue input
alaayehya
Community Member
mls qos srr-queue input dscp-map queue 1 threshold 2  9 10 11 12 13 14 15
mls qos srr-queue input dscp-map queue 1 threshold 3  0 1 2 3 4 5 6 7 32
mls qos srr-queue input dscp-map queue 2 threshold 1  16 17 18 19 20 21 22 23
mls qos srr-queue input dscp-map queue 2 threshold 2  33 34 35 36 37 38 39 48
mls qos srr-queue input dscp-map queue 2 threshold 2  49 50 51 52 53 54 55 56
mls qos srr-queue input dscp-map queue 2 threshold 2  57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3  24 25 26 27 28 29 30 31
mls qos srr-queue input dscp-map queue 2 threshold 3  40 41 42 43 44 45 46 47
what does these series of numbers mean 9 10 11 12 13 14 15 then 0 1 2 3 4 5 6 7 32?
from where this come and what does it mean?
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
It means DSCP marked packets of (9 10 11 12 13 14 15) are sent to queue 1 but with a tail drop setting 2.
It means DSCP marked packets of (0 1 2 3 4 5 6 7 32) are sent to queue 1 but with a tail drop setting 3.
Where it most likely comes from, something someone entered as an explicit cli command as the default settings wouldn't normally show.
Why this was done this way should depend on the QoS goals of your environment.
More information about these commands and/or usage can be found in the IOS reference and user guides for your device and IOS version; there's also often additional tech notes and/or white papers on using these features.
