mls qos trust command does not work
NAVIN PARWAL
Level 7
Level 7
Folks,
          I have a 3560 and when I try the "mls qos trust cos" command under the port channel interface it does not work. Any ideas?
The command does work under the indiviual interfaces but not under the port channel interface.
cat3560(config)#int port-channel 1
cat3560(config-if)#mls qos ?
% Unrecognized command
cat3560(config)#int gig 0/1
cat3560(config-if)#mls qos tr
cat3560(config-if)#mls qos trust dscp
Any help would be highly appreciated.
NAVIN PARWAL
Level 7
Level 7
Folks,
Hi Navin,
This is normal behavior. Valid interfaces are physical interfaces you can check the link below:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_58_se/configuration/guide/swqos.html#wp1042819
HTH,
Alex
*Please rate helpful posts
