10-20-2010 02:04 AM - edited 03-06-2019 01:37 PM
Does anyone know if there is a minimum version of s/w on 6500 Supervisor cards for this command to work? Currently I'm running 12.2(18)SXD7 and the command is not present.
James
10-20-2010 03:12 AM
JMatthews100 wrote:
James
James
According to the command references you need 12.2(33)SXI -
http://www.cisco.com/en/US/docs/ios/qos/command/reference/qos_m2.html#wp1044294
Jon
10-20-2010 03:45 AM
Makes sense. Thanks for the help.
James
