mls queue-sets
tedauction
Hello, my understanding is that you can use a queue-set as  a template to apply qos settings to an interface via a 'queue-set x' command, OR you can manually add those settings to an interface with the 'srr-queue bandwidth share x x x x' command.
Is this correct ?
Thank you kindly.
Francesco Molino
Queue-set is a template to define buffers for each queue while srr-queue bandwidth share is how you share the available bandwidth to reach queue.
Bandwidth will be the bandwidth you actually have on your interface while buffer is likes a storage space for interface.
By default all ports are using queue-set 1.
Hope this answers your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
Francesco
