Mode Conditioning Patch Cords for Multimode Fiber Gigabit Links around 1,000 Feet
NPT_2
Level 2
Level 2
Has anyone had good or bad luck using mode conditioning patch cords with 1000 LX SFP's and Gbic's over 62.5 multimode fiber optic cabling?  We have a location that only has 1,000 feet of Multimode Fiber optic cable to it and they are in need of Gigabit connectivity.  I know this is beyond the 700 ft limitation for 1000SX Optics and MMF, but the specs also show the possibility of using 1000 LX SFP's and Mode conditioning patch cords.
Has anyone had luck doing this (good or bad feedback helpful) or would it be best to just run new Single Mode Fiber optic cable to this location?
Jim
johnd2310
Level 8
Level 8
This should work. I have a few MMF links using GLC-LH-SMD sfp and mode-conditioning patch cable running fine for years.
John
**Please rate posts you find helpful**
johnd2310
Level 8
Level 8
John
Do you use one mode conditioning cable on each end of the link or just on one side of the link?  Also, is the offset on only one fiber or both the transmit and receive side?
Jim
Hello
I agree I have come across condtioning cabling on OM1 running over 700 meters -
If i remember it was on both ends of the connection
res
Paul
Kind Regards
Paul
As stated by Paul, you need mode-conditioning cable on both ends of the link. The offset is on one of the fibres (Transmit Fibre), hence the need for mode cable at both ends.
John
