Module is not support on 4507R
shajahan yusuff
Dears,
i have WS-X4624-SFP-E chassis module. i tried to implement on 4507R LanSwitches. after implement that module is not support on 4507R Switches. could you plese help us.
1. how can to resolve.
2. Give other module with support 4507R with sfp chassis module.
Thank You,
Shajahan.
Hi Shajahan,
E-Series line cards require E-Series chassis
These cards are classic line cards and should work in 4507R chasis.
WS-X4306-GB
Cisco IOS Software Release 12.1(8a)EW or later
WS-X4418-GB --
WS-X4448-GB-LX
WS-X4448-GB-SFP
Cisco IOS Software Release 12.2(20)EWA or later
WS-X4506-GB-T
Cisco IOS Software Release 12.2(20)EWA or later.
You can find these information below under individual line cards.
http://www.cisco.com/en/US/prod/collateral/modules/ps2710/ps5494/product_data_sheet0900aecd802109ea.html
Also you can check the release notes for supported hardware for that particular IOS version.
Subbiah
subma
Hi Shajahan,
For WS-X4624-SFP-E
Here are the minimum requirements:
Chassis: 4500 E-series chassis
Supervsior: Supervisor Engine 6-E and Supervisor engine 6L-E
IOS: Cisco IOSR Software Release 12.2(44) SG or later
Here are some of Classic Gigabit Ethernet Fiber (GBIC or SFP) Line Cards
WS-X4306-GB
WS-X4418-GB
WS-X4448-GB-LX
WS-X4448-GB-SFP
WS-X4506-GB-T
please review the below datasheet for your reference.
Hope this helps.
Subbiah
Dear subbiah,
Thank you. that mention module only support on 4507e chassis. i have for 4507 R Chassis. i went throu checked beow table.
Line Card
Number of Ports
Port Speed
Port Type
Wire Rate
Cisco Catalyst 4500 Series Min/Max Ports
4503-E
4506-E/
4507R-E/
4507R+E
4510R-E/
4510R+E
WS-X4306-GB
6
1000BASE-X
GBIC
Yes
6/12
6/30
6/42
WS-X4418-GB
18
1000BASE-X
GBIC
2 ports full
16 ports
4-to-1
7
18/36
18/90
18/126
WS-X4448-GB-LX
48
1000BASE-LX
48 SFPs (included)
8-to-17
48/96
48/240
48/384
WS-X4448-GB-SFP
48
1000BASE-X
SFP
8-to-17
48/96
48/240
48/384
WS-X4506-GB-T
6 + 6
10/100/1000
1000BASE-X (SFP) RJ-45 PoE IEEE 802.3af
and Cisco prestandard
Yes
6/12
6/30
6/42
need supported model on 4507R Chassis. need for with SFP 24 ports. our OS version is 12.2(25)EWA4. is it need to upgrade OS to support for the above list.
Thank You,
Shajahan.
Hi Shajahan,
WS-X4306-GB
WS-X4418-GB --
WS-X4448-GB-LX
WS-X4448-GB-SFP
WS-X4506-GB-T
Subbiah
