Module (x) VDB Temperature: N/O ??
aalbrecht27
I have a 6509 switch that isn't displaying all of the temperatures after doing a show environment command, please see the below output:
module 2:
  module 2 power-output-fail: OK
  module 2 outlet temperature: 38C
  module 2 inlet temperature: 36C
  module 2 VDB outlet temperature: 37C
  module 2 VDB inlet temperature: 36C
  module 2 VDB device-1 temperature: 37C
module 3:
  module 3 power-output-fail: OK
  module 3 outlet temperature: 37C
  module 3 inlet temperature: 36C
  module 3 VDB outlet temperature: N/O
  module 3 VDB inlet temperature: N/O
  module 3 VDB device-1 temperature: N/O
module 4:
  module 4 power-output-fail: OK
  module 4 outlet temperature: 37C
  module 4 inlet temperature: 36C
  module 4 VDB outlet temperature: 38C
  module 4 VDB inlet temperature: 37C
  module 4 VDB device-1 temperature: 38C
Can anybody explain what the above output for module 3 means?  Is it a bad temperature sensor?
Reza Sharifi
Is module number 3 a POE/voice card?
VDB stands for Voice Daughterboard
Yes it is.  It is model number WS-F6K-48-AF
