Monitor session can only capture one direction traffic
deepeshs
my config
On the dst port i can only see one direction (tx) traffic to the source port. Why would that be?
M1# show running-config interface ethernet 1/19
!Command: show running-config interface Ethernet1/19
!Time: Fri Sep 12 13:57:45 2014
version 6.0(2)N1(2)
  description ""
  switchport monitor
  speed 1000
M1# show running-config monitor all
!Command: show running-config monitor all
!Time: Fri Sep 12 13:57:04 2014
version 6.0(2)N1(2)
monitor session 10 type local
  no description
  source interface Ethernet103/1/13 both
  destination interface Ethernet1/19
M1# show monitor
internal   session
M1# show monitor session 10
   session 10
type              : local
state             : up
source intf       :
    rx            : Eth103/1/13
    tx            : Eth103/1/13
    both          : Eth103/1/13
source VLANs      :
    rx            :
source VSANs      :
    rx            :
destination ports : Eth1/19
Legend: f = forwarding enabled, l = learning enabled
Akash Agrawal
not able to understand exact query, but what i understand you are monitoring rx/tx traffic of port Eth103/1/13 and copy of that traffic sending on port Eth1/19 over which you must have connected a laptop with wireshark installed.
In such case on port Eth1/19, we will se Tx traffic only. Please correct me if i did not understand your query properly.
--Pls rate helpful posts--
Akash
Yes that is correct Akash.
My expectation was as I am capturing tx and rx on port  Eth103/1/13.
I should see on port 1/19 which is monitor port.
If that wouldn't not be the case what should I do to capture both tx and rx packets.
