Monitor session - Local SPAN - small output
ravensfast
I am having difficulties with getting SPAN traffic over my WS-X6704-10GE (CFC).
CISCO7606
ios 12.2(33)SRE6, SUP720-3BXL
Trying to use the span feature, put the commands listed below in and they entered successfully, but the port is not being mirrored.
interface TenGigabitEthernet1/1
description PUBLIC
dampening
mtu 9216
ip address x.x.x.x x.x.x.x
interface TenGigabitEthernet1/2
mtu 9216
no ip address
monitor session 1 source interface tenGigabitEthernet 1/1
monitor session 1 dest interface tenGigabitEthernet 1/3
show monitor session 1 detail
Session 1
Type                   : Local Session
Description            : -
Source Ports           :
RX Only            : None
TX Only            : None
Both               : Te1/1
Source VLANs           :
RX Only            : None
TX Only            : None
Both               : None
Source RSPAN VLAN      : None
Destination Ports      : Te1/3
Filter VLANs           : None
Dest RSPAN VLAN        : None
Source IP Address      : None
Source IP VRF          : None
Source ERSPAN ID       : None
Destination IP Address : None
Destination IP VRF     : None
Destination ERSPAN ID  : None
Origin IP Address      : None
IP QOS PREC            : 0
IP TTL                 : 255
show fabric utilization
slot    channel      speed    Ingress %     Egress %
1          0        20G            8            3
1          1        20G            3            8
4          0        20G            1            0
5          0         8G            0            0
6          0        20G            0            0
1          0        20G            8           20
1          1        20G           13            8
4          0        20G            0            0
5          0         8G            0            0
6          0        20G           12           12
Fabric utilization grow up.
TenGigabitEthernet1/1 is up, line protocol is up (connected)
5 minute input rate 868162000 bits/sec, 257246 packets/sec
5 minute output rate 2553331000 bits/sec, 322959 packets/sec
TenGigabitEthernet1/3 is up, line protocol is down (monitoring)
5 minute output rate 45000 bits/sec, 80 packets/sec
Output rate too small.
On other shelf with WS-X6704-10GE (DFC) work fine.
Could anyone help look at whether my "monitor session" statements are correctly configured.
Thanks.
singhaam007
Level 3
Level 3
hello,
try
monitor session 1 source interface tenGigabitEthernet 1/1 both
Please Rate this information helps thanks
