Switch Qos
bmurray
I have 2 Cisco 3560 switches trunked to each other. I have the following on both trunk interfaces. It is a point to point 10 meg link with a non
Cisco voip solution. There are 2 san devices at both sites trying to replicate data and when more than one replication happens the phone
quality breaks up.
interface GigabitEthernet0/23
description ***TW Trunk to 3560G Port 3 P2P****
switchport mode trunk
switchport nonegotiate
srr-queue bandwidth share 1 30 35 5
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust cos
auto qos trust
7 Replies 7
Mohamed Sobair
Level 7
Level 7
Your Config Looks Ok, except for the bandwidth share command as its not in effect as long as you have (bandwidth shape) configured on the interface. The Bandwidth shape command has precedence over it, and treats all other queues whic set to 0 value to be in a shared percentage. so you dont need it, you can remove it from the configuration.
Try to make sure your Phones on the Access Ports are set with the right QoS - CoS value, and there is a proper QoS configuration on the Access ports as well.
Mohamed
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Have you confirmed your VoIP and SAN replication traffic is correctly marked and getting into the correct queues?
You do this in both directions?
Have you checked for any other potential bottlenecks?
What are the best ways to verify qos tagging and operation?
Queue (1) is the priority Queue on your Switch, a CoS value of 5 should automatically be mapped to this queue.
To make sure your phones sets the right QoS - CoS value, you may use a network tester before even pluggin the IP-Phone to the Switch Port. On the Switch side, there is no specific command can reveal the CoS Value Sets on your phones.
If you are having difficulty getting a Tester, You Can Just Set all Access Ports on the Switch with the Proper CoS Value (5) where your Phones are connected and you should not experience such drop after that.
The Command On the Catalyst Switch is:
Interface G0/1
mls QoS CoS 5
priority-queue out
Like wise, it should be set for all Access Ports where the Phones are connected, notice, also the priority queue is set. This will make sure you have Classification and Marking at the Access and Proper QoS treatment from the Access to the Uplink where als the CoS value are trusted.
Mohamed
singhaam007
Level 3
Level 3
hello,
Qos is not easy to understand and it can get more confusing if you change its default behaviour.
All cisco phones mark there traffic with COS 5 and it get change into DSCP 46 at layer 3.
Please see this document for more detail information.
Please rate if this helps
thanks
Hi Amrinder,
Hey, that's a nice document! Did you write it yourself?
Apart from this, there is a good discussion and a fine in-depth document posted on CSC here:
https://supportforums.cisco.com/thread/2051188
https://supportforums.cisco.com/docs/DOC-8093
Best regards,
Peter
Hi Peter,
thanks mate.
i got it from my work mate. just keeping it on my hard drive coz its really good.
i am still learning.
but i will write one soon with some more details.
thanks so much for the links.
cheers
