Monitor Session on multiple switches to Voice Recorder
BrianChernish
I have a pair of Cisco 2960 switches (Stacked) in a VOIP environment. Trying to record the voice traffic.
The current set up is:
monitor session 2 source interface Gi1/0/21 - 22
monitor session 2 source interface Gi2/0/21 - 22
monitor session 2 destination interface Gi1/0/24
If this is correct;
Will the traffic that is sent to Gi1/0/24 be identical to the traffic sent to Gi2/0/24
Will all the traffic from both "sources" be sent to both "destinations?
Brian
Jaderson Pessoa
If this is correct;
Will all the traffic from both "sources" be sent to both "destinations?  <  on this case all traffic will be sent to G1/0/24
you have just one destination to session monitor 2.
Check it for more information: http://www.cisco.com/en/US/customer/docs/switches/lan/catalyst2960/software/release/12.2_55_se/configuration/guide/swspan.html#wp1036829
Regards.
Jaderson Pessoa
*** Rate All Helpful Responses ***
balaji.bandi
adding to other post :
if all the interface range in one Access VLAN then monitor the VLAN interface is good idea i guess.
also make sure monitor destination interface from access VLAN.
BB
