Monitor Session VLAN Limitation?
jnlawrence76
I am trying to add the following but it seems that I can not add over 5 entries.  Is there a limitation as to how many you can add? I cannot do a range for all of the VLANS as I am setting this up for our IPS to monitor and there are Voice VLANs in between the data VLANs that I do not want to monitor:
Trying to put in :
monitor session 1 source vlan 1 - 32 , 40 , 48 , 56 , 64 , 72 , 80 , 88 , 96 , 100 , 104 , 112 , 120 , 128 , 136 , 144 , 152 , 160 , 168 , 176 , 184 , 192 , 200 , 208 , 216 , 240 - 242 , 250
But the 6509 will only take:
If I try to add an additional one past 64, it gives me a "Invalid input detected at '^' marker." error.
Thanks in advance.
mgalazka
Jeremy,
You can accomplish this with multiple "monitor session 1 source vlan" config lines.  Please see my example below:
lab1(config)#monitor session 1 source vlan 2 , 4 , 6 , 8 , 10
lab1(config)#monitor session 1 source vlan 12 , 14 , 16 , 18 , 20
lab1(config)#do show run | i monitor
lab1(config)#do show monitor session 1
Session 1
Type                   : Local Session
Source VLANs           :
    Both               : 2,4,6,8,10,12,14,16,18,20
Egress SPAN Replication State:
Operational mode       : Centralized
Configured mode        : Centralized (default)
lab1(config)#
Matt
6 Replies 6
mgalazka
Jeremy,
Session 1
Source VLANs           :
lab1(config)#
Matt
Perfect....worked like a charm.  Thanks for your prompt response.
Thanks for the tip, very helpful!!
FCU-JE
Necromancing this topic just to add that it is still helpful and appears to be accurate in 2025 on IOS-XE 17.12.x software.
I could understand if there's some reason why they limit the number of VLAN ranges/entries that can be added in a single configuration command but I wish this were more intuitive to administrators at the very least in the `?` output.
I feel bad for admins (of which I consider myself one of) who for smaller environments still mostly rely on drafting configurations and then copy-pasting them in. It would be a very easy mistake for an admin to make to *think* that they can add as many VLAN entries/ranges they want in a single command but for this to end up not having the desired configuration.
FCU-JE
Support has helped me to open up an enhancement request for this, CSCwp17913
Personally I think an easy improvement to the way this works is to treat it similarly to `switchport trunk vlan add x` commands where you can just split the VLANs into their own commands but the result in the startup/running config shows as just one line.
Spoiler
Customer is requesting enhancement. It's easier to be able to define all interfaces on a single line rather than running the same command multiple times.
Symptom:
No choice to continue to use comma keyword:
Switch(config)#$vlan 1 - 50 , 100 - 150 , 200 - 250 , 300 - 350 , 400 - 450 ?
 both Monitor received and transmitted traffic
 rx Monitor received traffic only
 tx Monitor transmitted traffic only
 <cr> <cr>
Conditions:
C9200L-48T-4X-E
IOS-XE 17.12.4
Use comma more than 4 times on source interface.
Workaround:
Execute the same line with the missing interfaces.
Further Problem Description:
You need to execute the same line multiple times if you have more than 5 interface ranges.
Hmm, just wondering if the underlying logic, that parses the parameters, is shared with the "range" command, which I recall also limited itself to 5.
