Monitoring a VLAN
darren-carr
Level 2
Level 2
Guys
At present I use OP Manager to monitor my LAN. Sadly at present we have a very flat LAN in a single VLAN. I am looking at splitting up the LAN into multiple VLANs. I can easily route between the VLANs this has been tested. What I would like to do is to benchmark the current VLAN utilisation for broadcasts, multicasts, etc... start to migrate servers to the new VLANs and then benchmark again once I have finished. I can't really do this with OP Manager. Does anyone have any experience of using other tools to capture and model this data.
Darren
plumbis
Level 7
Level 7
ropethic
Level 4
Level 4
If you able to set up a span session, then make the source port the entire vlan.
For tools I would recommend Wireshark (ethereal) protocol analyzer. It is a free protocol analyzer you can use to monitor your traffic within the vlan.
www.wireshark.com
