Monitoring Interfaces and VLANs in ONE session?
roadrunner992
how can I monitor Interfaces and VLANs in one Monitor Session?
Problem is, that this monitored traffic needs to be send to ONE single destination port, what is not allowed to do with 2 seperate monitor sessions.
So my general problem is:
port 1 nees to be monitored
vlans 1,2,3 needs to be monitored
all traffic needs to be sent to
port 2
how can i do this?
hardware that i tried on and need a solution
1  WS-C3850-12S 03.07.00E cat3k_caa-universalk9 INSTALL
2 cisco WS-C4500X-32 cat4500e-universalk9.SPA.03.09.02.E.152-5.E2.bin
Thanks for help!
7 Replies 7
Mark Elsen
 - If you talk about monitoring traffic from the destinations that you mention then check : https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/CLIConfigurationGuide/Span.pdf
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
I know this type of session configuration. but on the given devices, its not possible its quite different to this:
xxxxxxxxxxxx(config)#monitor session 1
% Incomplete command.
You cannot jump in a special monior menu
you need to add the whole command:
xxxxxxxxxxxxxxx(config)#monitor session 1 source vlan 1
% Cannot add VLANs as sources for SPAN session 1
This message coming up because i already entered:
xxxxxxxxxxx(config)#monitor session 1 source interface gixxx
its not possible to add int and vlan on one session on these devices
balaji.bandi
I belive that is Limitation as per the information and device you have mentioned :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-3/configuration_guide/b_163_consolidated_3850_cg/b_162_consolidated_3850_cg_chapter_01000101.html
May be to look alternative how we can achieve, need more information below :
port 1 nees to be monitored   - is ths Trunk or access port ?
vlans 1,2,3 needs to be monitored  - is this Layer 3 Interfaces ?
If you have Trunk Interface can be achived with VLAN filter in that config (you can refer above document)
BB
port 1 - yes is a trunk
vlans 1,2,3 yes layer 3 with definated subnets
the port 1 is a uplink interface, the vlans are present on that switches and are routed over thes switches(core)
is there another image, we can install to get these functions, ineed?
any1 can help? do we need a new stich model or can we use another licence/software version?
If the port 1 Trunk have all the VLAN passing, you can use filter to get all information and destination port to port2
look at the example config the URL i have provided.
BB
The problem is,
the vlan traffic is internal and not only on this port.
