Monitoring Problem
Patrick McHenry
Level 7
Level 7
Trying to post but the site tells me it can't be posted because of content. Are there things that cannot be posted?
Thanks, Pat.
John Blakley
What are you trying to post? You can attach compressed files, images, and docs AFAIK...
HTH, John *** Please rate all useful posts ***
I was just trying to post some output from show commands. It was rather long but, not too long.
You should be able to do that with no problems... I'm not sure if a normal forum post has a limit, but you could break it up into two posts if needed..
