MPLS ATOM: Can not get imposition rewrite string
klausschneider
I´ve got this message when configuring a vpls between c7206(ios15) and 3750me, below follows my config:
CE===(f1/0/2)c3750 (f1/0/1)=====(g0/1.100)c7206(g0/2.101)===CE
c3750:
system mtu routing 1500
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip ospf network point-to-point
interface FastEthernet1/0/1
switchport trunk allowed vlan 100
switchport mode trunk
interface FastEthernet1/0/2
switchport trunk allowed vlan 101
interface Vlan100
ip address 10.0.0.1 255.255.255.0
mpls label protocol ldp
mpls ip
interface Vlan101
no ip address
xconnect 2.2.2.2 666 encapsulation mpls
router ospf 100
router-id 1.1.1.1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 10.0.0.0 0.0.0.255 area 0
mpls ldp router-id Loopback0 force
c7206:
interface GigabitEthernet0/1.100
encapsulation dot1Q 100
ip address 10.0.0.2 255.255.255.0
no snmp trap link-status
ip ospf mtu-ignore
mpls ip
interface GigabitEthernet0/2.101
encapsulation dot1Q 101
no cdp enable
xconnect 1.1.1.1 666 encapsulation mpls
interface Loopback1
ip address 2.2.2.2 255.255.255.255
router ospf 100
network 2.2.2.2 0.0.0.0 area 0
mpls ldp router-id Loopback1 force
c3750#sh mpls l2transport vc det
Local interface: Vl101 up, line protocol up, Eth VLAN 101 up
  Destination address: 2.2.2.2, VC ID: 666, VC status: down
    Output interface: if-?(0), imposed label stack {}
    Preferred path: not configured
    Default path: active
    Next hop: Invalid MOI
  Create time: 00:52:45, last status change time: 00:00:04
  Signaling protocol: LDP, peer 2.2.2.2:0 up
    MPLS VC labels: local unassigned, remote 18
    Group ID: local unknown, remote 0
    MTU: local unknown, remote 1500
    Remote interface description:
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 0, send 0
    byte totals:   receive 0, send 0
    packet drops:  receive 0, send 0
c3750# sh logg
00:54:11: %LDP-5-NBRCHG: LDP Neighbor 2.2.2.2:0 (1) is UP
00:54:17: ATOM: Can not get imposition rewrite string
00:54:33: ATOM: Can not get imposition rewrite string
00:54:36: tagcon: background scan: Start
00:54:36: tagcon: background scan: End
00:54:40: %LDP-5-CLEAR_NBRS: Clear LDP neighbors (*) by vty0 (10.0.0.2)
00:54:40: %LDP-5-NBRCHG: LDP Neighbor 2.2.2.2:0 (1) is DOWN (User cleared session manually)
00:54:40: AToM MGR [2.2.2.2, 666]: Delete remote vc label binding
00:54:40: AToM MGR [2.2.2.2, 666]: Update local vc label binding
00:54:45: %LDP-5-NBRCHG: LDP Neighbor 2.2.2.2:0 (2) is UP
00:54:45: AToM MGR [2.2.2.2, 666]: Advertise local vc label binding
00:54:45: AToM MGR [2.2.2.2, 666]: Remote end up, inst 2
00:54:45: AToM MGR [2.2.2.2, 666]: Validate vc, activating data plane
00:54:45: AToM MGR [2.2.2.2, 666]: Receive SSM dataplane up notification
00:54:45: AToM MGR [2.2.2.2, 666]: Dataplane activated
00:54:45: AToM MGR [2.2.2.2, 666]: Remote end down, vc is down
00:54:45: AToM MGR [2.2.2.2, 666]: Unprovision SSM segment
00:54:47: ldp: ldp start; tbl 0
00:54:48: ATOM: Can not get imposition rewrite string
00:54:48: AToM MGR [2.2.2.2, 666]: Local end down, vc is down
00:54:48: AToM MGR [2.2.2.2, 666]: Unprovision SSM segment
00:54:48: AToM MGR [2.2.2.2, 666]: Label 18 free for reuse in 201 sec
00:54:48: AToM MGR [2.2.2.2, 666]: Label 18 released while on hold, reduce hold time to 21 sec
c7206#sh mpls l2transport vc det
Local interface: Gi0/2.101 up, line protocol up, Eth VLAN 101 up
  Destination address: 1.1.1.1, VC ID: 666, VC status: down
    LFIB entry present
    Output interface: unknown, imposed label stack {}
  Create time: 01:01:06, last status change time: 00:00:09
  Signaling protocol: LDP, peer 1.1.1.1:0 up
    MPLS VC labels: local 20, remote unassigned
    Group ID: local 0, remote unknown
    MTU: local 1500, remote unknown
  VC statistics:
c7206#show logg
*Mar 19 21:18:25.303: AToM MGR [1.1.1.1, 666]: Remote end up
*Mar 19 21:18:25.303: AToM MGR [1.1.1.1, 666]: Validate vc, activating data plane
*Mar 19 21:18:25.303: AToM MGR [1.1.1.1, 666]: Remote end down, vc is down
*Mar 19 21:18:25.303: AToM SMGR [1.1.1.1, 666]: Processing imposition update, vc_handle 5297220, update_action 1, remote_vc_label 19
*Mar 19 21:18:25.303: AToM SMGR [1.1.1.1, 666]: Imposition Programmed, Output Interface: Gi0/1.100
*Mar 19 21:18:25.303: AToM SMGR [1.1.1.1, 666]: Processing disposition update, vc_handle 5297220, update_action 1, local_vc_label 20
*Mar 19 21:18:25.303: AToM SMGR [1.1.1.1, 666]: Processing imposition update, vc_handle 5297220, update_action 0, remote_vc_label 19
*Mar 19 21:18:25.303: AToM SMGR [1.1.1.1, 666]: Imposition Disabled
*Mar 19 21:18:25.303: AToM SMGR [1.1.1.1, 666]: Processing disposition update, vc_handle 5297220, update_action 0, local_vc_label 20
*Mar 19 21:18:25.303: AToM SMGR: Processing TFIB event for 1.1.1.1
*Mar 19 21:18:25.303: AToM SMGR: TFIB scan started
*Mar 19 21:18:25.303: AToM SMGR: TFIB scan complete
Move fa1/0/1 to one of the ES ports as MPLS functionality is only supported on them.  Those are the SFP ports, g1/1/1, g1/1/2.  Also note that these ports will only work at gig speed, not fast ethernet.
-Matt
klausschneider
More detailed debug messages from 3750me:
00:17:50: AToM MGR [2.2.2.2, 666]: Local end down, vc is temporarily down
00:17:50: AToM MGR [2.2.2.2, 666]: Unprovision SSM segment
00:17:50: AToM MGR [2.2.2.2, 666]: Label 19 free for reuse in 202 sec
00:17:50: AToM MGR [2.2.2.2, 666]: Receive SSM dataplane up notification
00:17:50: AToM MGR [2.2.2.2, 666]: Label 19 released while on hold, reduce hold time to 20 sec
-Matt
Thank you matthew
