MPLS implementation in a LAN
platignum
Hi everyone,
I have been researching MPLS for a few days now with the intention of setting up a network to test MPLS operations using 2651xm routers and 2950 switches.
Presently Iam simply gathering general information before I start the project.
If anyone has had any experience of a similar setup or just MPLS in general I would be grateful for your comments.
I would also appreciate any links to informational sites or case studies that you have found.
One of my main aims here is to test VLAN operations in a LAN usng MPLS.
All comments and or suggestions will be gratefully accepted.
Janet
Thanks a million.
The documentation you provided proved to be very useful in aiding my understanding, which led me to http://www.juniper.net/techpubs/software/erx/junose61/swconfig-link/html/bridged-ethernet-config5.html
Just when I was beginning to think there was no light at the end of the tunnel...........
Cheers
Janet
