upgrading firmware question
jjoseph01
Level 3
Level 3
Well, I have very little experience with the 6000 with a MSFC card in it, which is what I found out today that this switch has. My question is this: if I upgrade the switch CatOS firmware, do I have to upgrade the MSFC firmware as well?
mohammedmahmoud
Level 11
Level 11
Hi John,
CatOS image is used as the system software to run the Supervisor Engine on Catalyst 6500/6000 switches. If the optional MSFC is installed, a separate Cisco IOS Software image is used to run the MSFC (so no relation between both). This combination is called a Hybrid mode.
Did you think about converting the switch from CatOS to IOS --> Cisco IOS Software on both the Supervisor Engine and MSFC (Native): a single Cisco IOS Software image can be used as the system software to run both the Supervisor Engine and MSFC on Catalyst 6500/6000 switches.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008070f124.shtml
HTH, please rate if it does,
Mohammed Mahmoud.
mohammedmahmoud
Level 11
Level 11
Hi John,
Mohammed Mahmoud.
