MPLS SVI Question
WimVS
Hey,
I have following simple setup:
R1--------R2 with a trunk link in between. Connected on e0/0 (both sides)
Following config on R1:
interface Vlan1
 ip address 10.10.10.1 255.255.255.252
 mpls ip
interface Ethernet0/0
 switchport mode trunk
 duplex auto
Same config on R2 but with ip 10.10.10.2.
Problem I encounter is they are not forming an ldp session. Maybe not possible?
show mpls ldp discovery:
Local LDP Identifier:
10.10.10.1:0
Discovery Sources:
Interfaces:
Vlan1 (ldp): xmit
show mpls interfaces
Interface IP Tunnel BGP Static Operational
Vlan1 Yes (ldp) No No No Yes
Any suggestions are welcome.
Thanks.
the general guideline is that MPLS is a layer 3 connection, and an 802.1Q trunk is a layer 2 protocol, so you cannot have an 802.1Q trunk across a MPLS connection. You need something like 802.1Q tunneling to expand your VLAN.
Thanks, I'll look into that.
