MS130 Virtual Stack
faizal_vi
Level 3
Level 3
HI,
Does MS 130 supports virtual stack?
I dont see MS130 listed under stacking cables in the below link.
https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Small-Form_Factor_Pluggable_(SFP)_and_Stacking_Accessories
MF
joey.debra
Meraki Community All-Star
I believe the true Meraki lingo has always been:
Virtual stacking = just putting all the ports on one page (great feature, but nothing to do with the switches itself)
Physical stacking = backplane stacking with two cables
Flexible stacking = having switches transform regular ports into stacking ports which in Cisco classic is actually called virtual stacking 😜 Lovely confusion there.
mloraditch
Virtual stacking is nothing more than a marketing name for the dashboards ability to edit every port in a network at once using the switch port settings page.
Physical stacking requires dedicated cables and the MS130 do not support that.
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
MerakiGnome
A bit like “zero touch” deployments @mloraditch
Darren OConnor
https://www.linkedin.com/in/darrenoconnor
joey.debra
Thanks for this answer, @joey.debra! I'm marking it as the solution. @faizal_vi - if this does not answer your question, please let us know what further clarifications you need.
Cheers!
