MS150..?
tyshawn76
Level 7
Level 7
I've been in a few webinars and I caught a slide that referenced the MS150 line of switches. Has anyone seen or have a bit more information on these switches?
If you found this post helpful, please give it Kudos. If my answer solves your problem please click Accept as Solution so others can benefit from it.
Brash
Meraki Community All-Star
Nothing I can find other than what appears to be a publicly posted slide from 2024 GSX with a few bits and pieces.
60W UPOE
5G mgig ports
4x 10G SFP Uplinks
Layer 2+ stacking
Planned release Q3 2025
70 Replies 70
CMR
Nothing here, just someone saying 3 months ago that it was coming...?
Brash
60W UPOE
5G mgig ports
4x 10G SFP Uplinks
Layer 2+ stacking
publicly posted slides from 2024 GSX... sigh, this is why we can't have nice things 🤣
Technical Leader - Meraki Product Management: Switching / ccie 50782
CMR
@brennmar we need a 🤣 emoji alongside the Kudo ⬆️...
Rasmus Hoffmann Birkelund
I think I understood Meraki as saying they plan on retiring most of their switching platforms to only be MS130 and MS150, and those MS2xx and up to be replaced by Catalyst switches in Meraki persona.
I think maybe that MS150 might be planned to replace MS2xx (My words, not Cisco's).
MS150 will be targeted as a Low-end platform positioned for WiFi7, as well as support for Adaptive Policies and Perpetual PoE.
LinkedIn ::: https://blog.rhbirkelund.dk/
Like what you see? - Mark as helpful ## Did it answer your question? - Mark it as a Solution 🙂
All code examples are provided as is. Responsibility for Code execution is solely your own.
They are already listed as "compatible Switches" in the Subscription page of the dashboard.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
mloraditch
Based on the normal way Cisco likes to make announcements, I would strongly suspect Cisco Live Amsterdam (2/9-14) will be when they are released.
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
inderdeepsingh1
Level 11
Level 11
Check the below in coming two months and you will see the update
https://meraki.cisco.com/product-collateral/ms-family-datasheet/?file
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
tyshawn76
Level 7
Level 7
Thank you everyone who replied to this odd request.
CDTC
Community Member
I see them listed on the website now. No documentation thought.
CMR
Two 60W 1/5Gb PoE++ models
Six 30W 1Gb PoE+ models
Four 1Gb non PoE models
They might have 100Gb stacking as the accessories has the 100Gb cables...
Page is here: Cloud-Managed 24 GE Network Switch | MS150 | Cisco Meraki
CMR
And if I read the page correctly, stacking is confirmed... I think they are pure layer 2, or they would have been MS255s...
I'm kind of Meh on the port configuration. In a perfect world would love to see
24 port
4 SFP+
8 Port 10G UPOE
16 Port 2.5 POE or UPOE
Less Perfect world
4 SFP+
8 Port 10G UPOE
8 Port 2.5 POE or UPOE
8 1G POE+
@CMR thanks for the extra detail and links good sir.
CMR
I like the PoE++ models, but think the PoE+ and non PoE are a bit poor, being all 1Gb. I can however see their use in schools, replacing MS2xx or C2960X edge switches with C9300s at the core.
