04-07-2025 05:28 AM
Hi all,
I've an CS220-48F switch. I need to add an uplink with this spec : 100mb on Single-mode fiber optic. Can I do this ? I tried it, but it dosent work ? The port must be 1Gb or 100mb could work ?
Thank for Help
Solved! Go to Solution.
04-08-2025 06:48 AM
No. transceivers have hard coded speeds.
04-07-2025 05:32 AM
There are no Meraki devices that accept a 100mb SFP
04-08-2025 12:33 AM
Can I force the transceiver to communicate at 100mb
04-08-2025 06:48 AM
04-08-2025 07:42 AM
All the above is correct however, if you're trying to 'engineer' a way for this to work, you could look to use an RJ45 port which you could force into 100MB and then use 3rd party media convertors to convert between copper & SMF.
