MST
jeansamarani
we are planning to setup a network as per the attached design. I would like to know if there will any conflict or Interoperability issue between the different stp mode running on the different switches.
thanks
Jean
Giuseppe Larosa
Hello Jean,
it should be fine MST is backward compatible with PVST on a per port basis
the links have to be 802.1Q trunks to be able to detect a PVST neighbor
you need to make the MST the root bridge for all vlans.
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/50sg/configuration/guide/spantree.html#wp1083304
Hope to help
Giuseppe
