receive discards on switch - please help
carl_townshend
Hi all, we have an issue with a router to switch connection, the speed and duplex are set to fixed on both sides, I have replace the cable and changed the port on the switch, but the switch is seeing receive discards,
any ideas what is causing this?
Many thanks
Carl
Tshi M
Level 5
Level 5
What speed are using? Do you have an ACL applied to the switchport?
hi, no acl applied to switchport, speed is 100 meg
I had this problem with multicast traffic running on 10/100 module 6500. once we changed to 1G port module 6500, the problem was gone.
