MST
ericdavis
Community Member
I have an interesting STP problem.  I am a little fuzzy on exactly how MST is supposed to work with one region configured.  I have one region with instances 0 an 1 set as the root on my core 6513. I have 2 distribution switches each connected to the core and then an access switch dual homed to each distribution switch.  I assumed that each distribution switch would set the uplink to to the core as the root port, but it seems one of them is not behaving the way i expected.  Why would it choose a port that has a higher root path cost as root port?  I'm totally confused on this.  See the below from the distribution switch in question.   Since I have one region why is my core 6513 not the regional root as well?  Any help is greatly appreciated.
##### MST0    vlans mapped:   none
Bridge        address 0026.cb68.da40  priority      32768 (32768 sysid 0)
Root          address f0f7.55be.bac0  priority      24576 (24576 sysid 0)
              port    Gi2/2           path cost     2000
Regional Root address 0026.cb68.da00  priority      32768 (32768 sysid 0)
                                      internal cost 40000     rem hops 18
Operational   hello time 2 , forward delay 15, max age 20, txholdcount 6
Configured    hello time 2 , forward delay 15, max age 20, max hops    20
Interface        Role Sts Cost      Prio.Nbr Type
Te1/1            Altn BLK 2000      128.1    P2p Bound(RSTP)
Gi2/1            Altn BLK 20000     128.65   P2p
Gi2/2            Root FWD 20000     128.66   P2p
ericdavis
Community Member
I can answer my own question a little bit, but I could use some help with the rest.  After reading some more it seems like my MST has been divided into more than one region, thus the P2p Bound(RSTP) on the Ten 1/1 port.  But I have no idea why since I used the same configuration name, same revision number and same instance mappings on all the switches.  Can someone shed some light?
