MTP/MPO crossover cables or straight through?
sean_evershed
Level 7
Level 7
I'm looking to deploy a pair of 6500s running VSS.
VSS will be established over a pair of 40GBASE-SR4 QSFP+ transceivers in each switch.
Do we need MTP/MPO crossover cables or straight through cables to connect the QSFPs?
Since the two switches are sitting side by side the MTP/MPO cables will be passed directly between the two racks.
As a result there will be no intervening fibre fobots used.
Sean
Gabriel Hill
