multicast and nexus 7k
we have two nexus 7k with ios version 6.1 are working as a core switches .
also we have L2 switches 2960 in the floors to connecting users in the network.
each 2960 switch is connected with two cores using VPC (TRUNK).
two cores have all vlan interface ip and working using HSRP.
the multicast server is connected in the switch 2960 in the VLAN 201 and it have multicast ip 239.10.10.20 with ip add 10.10.10.20.
also we need all user in the different VLANs in the floors to receive multicast traffic from server as per drawing attached.
what is the best configuration requied to applied in the two cores (N7K) to work as multicast redandancy and floors switches 2960 to work multicast.
please advice me .
Reza Sharifi
You just need to enable PIM on the 7Ks under each SVI, So mulicast can work between vlans.
switch(config)#feature pim
switch(config)#interface Vlanxxx
(config-if)ip pim sparse-mode
i configure and enable PIM on the interfeace VLAN but do not work properly.
also we need the configuration requied to applied in the two cores (N7K) to work as multicast redandancy using MSDP with auto RP technology .
regards ,
