Multicast and Port Channel
Fernando Soto
Hi. Sorry for my English
I have this switch:
WS-C2960G-24TC-L
15.0(1)SE2
C2960-LANBASEK9-M
I am injecting  multicast traffic to interface giga0/19 (vlan 110),
it come out to interface giga 0/11 , but it does not come out through the interface Port-channel1,
This is the configuration:
switchport trunk allowed vlan 100,110
switchport mode trunk
switchport nonegotiate
load-interval 30
speed nonegotiate
interface GigabitEthernet0/19
switchport access vlan 110
switchport mode access
load-interval 30
no cdp enable
spanning-tree portfast
interface GigabitEthernet0/11
description HCU-200
load-interval 30
no ip igmp snooping
SW1POP36#show interfaces gigabitEthernet 0/19
GigabitEthernet0/19 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0027.0c80.ac13 (bia 0027.0c80.ac13)
Description: TO-MK-TV-CARD
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input 00:00:01, output 00:00:07, output hang never
Last clearing of "show interface" counters 00:01:08
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 5291000 bits/sec, 491 packets/sec
30 second output rate 386000 bits/sec, 34 packets/sec
33975 packets input, 45984501 bytes, 0 no buffer
Received 33965 broadcasts (33812 multicasts)
0 watchdog, 33812 multicast, 0 pause input
41 packets output, 2624 bytes, 0 underruns
1 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
SW1POP36#show interfaces gigabitEthernet 0/11
GigabitEthernet0/11 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 0027.0c80.ac0b (bia 0027.0c80.ac0b)
Description: HCU-200
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 255/255, txload 13/255, rxload 1/255
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:02:31
30 second input rate 0 bits/sec, 0 packets/sec
30 second output rate 5414000 bits/sec, 500 packets/sec
64 packets input, 4096 bytes, 0 no buffer
Received 64 broadcasts (0 multicasts)
0 watchdog, 0 multicast, 0 pause input
75421 packets output, 102094892 bytes, 0 underruns
0 unknown protocol drops
SW1POP36#
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 0027.0c80.ac15 (bia 0027.0c80.ac15)
Description: ARSAT-IN
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 44/255
Full-duplex, 1000Mb/s, link type is force-up, media type is unknown
Members in this channel: Gi0/21 Gi0/22
Last input 00:00:01, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:03:03
30 second input rate 352504000 bits/sec, 34434 packets/sec
30 second output rate 0 bits/sec, 0 packets/sec
6757074 packets input, 8727505868 bytes, 0 no buffer
Received 264915 broadcasts (264886 multicasts)
0 watchdog, 264886 multicast, 0 pause input
164 packets output, 15214 bytes, 0 underruns
SW1POP36#
Giuseppe Larosa
Hello Fernando,
your switch is in End of Support since July 2017
see
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-series-switches/end_of_life_c51-674040.html
With igmp snooping disabled check the show interface of member links gi0/21 and gi0/22
Hope to help
Giuseppe
