Multicast flood to mrouter port between two switch
tony4336
Dear friends,
I have a flat L2 network, topology are as below:
Group of Crestron NVX streamer --> Switch A 2960X --> Core switch 2960X --> Switch B  2960X --> another group of Streamer
IGMP V2 are enable for all switch, IGMP snooping querier enable on Core switch, stream are working normally within their own switch (inside Switch A or B), however, all stream flood to the trunk link between Switch A/ B to Core Switch, but drop after arrived Core switch, seems the all multicast data forwarded to the Querier (mrouter) location, how to limited the multicast data only happen on onw switch but not forward to the querier?
Giuseppe Larosa
Hello @tony4336 ,
this is normal for IGMP snooping if a port is classified as mrouter port it will not be subject to IGMP snooping and all known multicast groups are flloded to it.
The port is classified as mrouter port if PIM messages or IGMP queries are received on it and this is what happens with IGMP querier on the core switch,
You would need PIM snooping that I'm afraid is not avaiable on your switch platforms to have a more intelligent managemt of traffic to mrouter ports.
Hope to help
Giuseppe
Hello
Just to confirm , you don’t have ip M/C enabled and you wish to using MC between hosts within the SAME vlan over trunks vis the core switch?
If you have enabled igmp snooping querier already make sure the l3 interface of the vlan has an ip address and is enabled?
show ip igmp interface vlan x
Kind Regards
Paul
Hi Paul,
Here are some of my setting related to Multicast
ip igmp snooping vlan 101 querier address 192.168.1.254
no ip igmp snooping vlan 1
ip igmp snooping vlan 101 immediate-leave
no ip igmp snooping vlan 100
interface GigabitEthernet1/0/48
switchport mode trunk
no ip igmp snooping tcn flood
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface Vlan1
ip address 192.168.0.253 255.255.255.0
interface Vlan101
ip address 192.168.1.253 255.255.255.0
Switch#sh ip igmp snooping
Global IGMP Snooping configuration:
IGMP snooping : Enabled
IGMPv3 snooping (minimal) : Enabled
Report suppression : Enabled
TCN solicit query : Disabled
TCN flood query count : 2
Robustness variable : 2
Last member query count : 2
Last member query interval : 1000
Vlan 1:
IGMP snooping : Disabled
CAPWAP enabled : Disabled
IGMPv2 immediate leave : Disabled
Multicast router learning mode : pim-dvmrp
Vlan 100:
Vlan 101:
IGMPv2 immediate leave : Enabled
CGMP interoperability mode : IGMP_ONLY
Switch#sh ip igmp snooping mrouter
Vlan ports
101 Gi1/0/48(dynamic)
Switch#sh ip igmp snooping querier
Vlan IP Address IGMP    Version      Port
101 192.168.1.254       v2              Gi1/0/48
Switch#sh ip igmp snooping groups
Vlan Group                    Type   Version Port List
101 224.0.1.129           igmp   v2        Gi1/0/1, Gi1/0/11, Gi1/0/48
101 239.9.0.0               igmp   v2        Gi1/0/11, Gi1/0/48
101 239.9.0.1               igmp   v2        Gi1/0/11, Gi1/0/48
101 239.255.255.250   igmp   v2        Gi1/0/1, Gi1/0/11, Gi1/0/48
101 239.255.255.255   igmp   v2        Gi1/0/1, Gi1/0/11, Gi1/0/48
*** All multicast fordwarded to Gi1/0/48 which dynamic set to mrouter port
This is the Core switch
no ip igmp snooping vlan 1 querier
no ip igmp snooping vlan 100 querier
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface Vlan1
ip address 192.168.0.254 255.255.255.0
interface Vlan101
ip address 192.168.1.254 255.255.255.0
Vlan 1:
Vlan 100:
Vlan 101:
101    192.168.1.254     v2                      Switch
Vlan   ports
101   Switch
101        224.0.1.129           igmp      v2                 Gi0/7, Gi0/8
101        239.9.0.0               igmp      v2                 Gi0/7
101        239.9.0.1               igmp      v2                 Gi0/7
101        239.9.0.16             igmp      v2                 Gi0/8
101        239.9.0.17             igmp      v2                 Gi0/8
101        239.255.255.250   igmp      v2                 Gi0/7, Gi0/8
101        239.255.255.255   igmp      v2                 Gi0/7, Gi0/8
*** All the multicast from edge switch forward to the Core switch, but no receiver request for this stream, thus it dones't goes to Gi0/8 ( another set of same video encoder config
Do I miss any setting or I can apply some filter to block the multicast forward to the Core switch but still place the Querier in the Core switch?
Giuseppe Larosa
Hello @tony4336 ,
Hope to help
Giuseppe
Hi Giuseppe,
I think you are right, so can I set some filter but still place the IGMP querier into the Core switch without forward all multicast to the mroute port?
