Multicast is not transported when a device with multiple multicast
gildson-pieter
Hi all
Multicast is not transported when a device with multiple multicast stream is connected to the switch.
As soon as we switch to a single stream it is working.
We have 7 single stream video controllers (C10 Optelecom-nkf) that are working fine.
2 video controllers (C23 Optelecom-nkf) with mutiple streams do not work when casting multiple streams.
I have searched in cisco BUG's but can find any related corresponding issues.
I have a feeling it might be related to the IOS license, but can not find a direct answer when searching online.
We are currently running lanbase 15.2(8)E5
This issue started after replacing the old cisco 2955 for the current ie-4010
Can you help us?
chrihussey
Is it strictly a layer 2 switch and is the connection to the C23 Optelecom-nkfs a single VLAN access port? Are you routing multicast on your network, if so where is the layer 3 interface for that VLAN?
