9300 switch, showing prompt switch:
Hi all,
I have a 9300 switch, after boot stuck in rommon mode prompt switch:
How can I make the switch to boot in normal mode, please advise
i also try boot from USB, its showing me below output
switch: Dir usbflash0:
Size Attributes Name
32768 drw- System Volume Information
1018097396 -rw- cat9k_iosxe.17.06.01.SPA.bin
711506601 -rw- cat9k_iosxe.16.09.05.SPA.bin
switch: boot usbflash0:cat9k_iosxe.17.06.01.SPA.bin
boot: attempting to boot from [usbflash0:cat9k_iosxe.17.06.01.SPA.bin]
boot: reading file cat9k_iosxe.17.06.01.SPA.bin
MM [1] MCU version 218 sw ver 215
MM [2] MCU version 218 sw ver 215
MCU UPGRADE IN PROGRESS... PLEASE DO NOT POWER CYCLE!!
Front-end Microcode IMG MGR: found 4 microcode images for 1 device.
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_0 update needed
: no
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_1 update needed
: yes
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_2 update needed
: yes
Image for front-end 0: /tmp/microcode_update/front_end/fe_type_6_3 update needed
: no
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0], index=0 ...594412 b
ytes.... Skipped[0].
Front-end Microcode IMG MGR: Preparing to program device[0], index=1 ...550244 b
ytes.
Front-end Microcode IMG MGR: Programming device 0...rwRrrrrrrw..0%..............
.......10%......................................................................
.................................20%............................................
..........................................................30%...................
..40%...........................................................................
............................50%.................................................
.....................................................60%........................
...............................................................................7
0%..............................................................................
......................80%.......................................................
................................................90%.............................
..........................................................................100%
Front-end Microcode IMG MGR: Preparing to program device[0], index=2 ...24506 by
tes.
Front-end Microcode IMG MGR: Programming device 0...rrrrrrw..0%....10%....20%...
...30%...40%....50%......60%....70%.....80%....90%....100%w
Wating for MCU to come up .....Rr!
Front-end Microcode IMG MGR: Microcode programming complete for device 0.
Front-end Microcode IMG MGR: Preparing to program device[0], index=3 ...90974 by
tes.... Skipped[3].
Front-end Microcode IMG MGR: Microcode programming complete in 358 seconds
MCU UPGRADE COMPLETED!!...
Both links down, not waiting for other switches
Switch number is 2
Chassis 2 reloading, reason - Active/standby selection failed in 1+1 Mode
Jun 29 09:28:26.069: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting:
reload fp action requested
Jun 29 09:28:27.550: %PMAN-5-EXITACTION: R0/0: pvp: Process manager is exiting:
rp processes exit with reload switch code
Initializing Hardware......
System Bootstrap, Version 17.6.1r[FC2], RELEASE SOFTWARE (P)
Compiled Wed 05/12/2021 15:39:34.01 by rel
Current ROMMON image : Primary
Last reset cause : SoftwareReload
C9300-48U platform with 8388608 Kbytes of main memory
boot: attempting to boot from [flash:packages.conf]
boot: reading file packages.conf
@Virendra Prajapati
 It seems the problem is related to this "Chassis 2 reloading, reason - Active/standby selection failed in 1+1 Mode"
There is a proposal solution on this link
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-9300-series-switches/212912-catalyst-9000-switches-booting-to-switch.html
Solution
Unset the Stack 1+1 variable. After this switch is able to boot normally.
just change the variables accordingly
switch:unset STACK_1_1
switch: set
ABNORMAL_RESET_COUNT=0
AUTOREBOOT_RESTORE=1
BOARDID=20569
BOOT=flash:packages.conf
BSI=0
MAC_ADDR=00:ab:cd:ef:01
MANUAL_BOOT=yes
MODEL_NUM=C9300-48UXM
MODEL_REVISION_NUM=D0
MOTHERBOARD_ASSEMBLY_NUM=73-17959-06
MOTHERBOARD_REVISION_NUM=A0
MOTHERBOARD_SERIAL_NUM=XXXXXXXXXXX
RANDOM_NUM=1901228755
RET_2_RCALTS=
ROMMON_AUTOBOOT_ATTEMPT=3
SWITCH_IGNORE_STARTUP_CFG=1
SWITCH_NUMBER=2
SYSTEM_SERIAL_NUM=XXXXXXXXXX
TEMPLATE=access
VERSION_ID=V01
5 Replies 5
I also try emergency-install by USB, but getting same issue........
switch: emegency-install usbflash0:cat9k_iosxe.17.06.01.SPA.bin
monitor: command "emegency-install" not found
switch: emergency-install usbflash0:cat9k_iosxe.17.06.01.SPA.bin
WARNING: The system partition (bootflash:) will be erased during the system reco
very install process.
Are you sure you want to proceed? [y] y/n [n]: y
Starting system recovery (usbflash0:cat9k_iosxe.17.06.01.SPA.bin) ...
boot: attempting to boot from [sda9:cat9k-recovery.SSA.bin]
boot: reading file cat9k-recovery.SSA.bin
PLATFORM_TYPE C9300 speed 9600
Booting Recovery Image 16.6.1
Initiating Emergency Installation of bundle usbflash0:cat9k_iosxe.17.06.01.SPA.b
in
Reading bundle usbflash0:cat9k_iosxe.17.06.01.SPA.bin...
Validating bundle usbflash0:cat9k_iosxe.17.06.01.SPA.bin...
Installing bundle usbflash0:cat9k_iosxe.17.06.01.SPA.bin....
Verifying bundle usbflash0:cat9k_iosxe.17.06.01.SPA.bin...
Package cat9k-cc_srdriver.17.06.01.SPA.pkg /temp//stage/cat9k-cc_srdriver.17.06.
01.SPA.pkg is Digitally Signed
Package cat9k-espbase.17.06.01.SPA.pkg /temp//stage/cat9k-espbase.17.06.01.SPA.p
Package cat9k-guestshell.17.06.01.SPA.pkg /temp//stage/cat9k-guestshell.17.06.01
Package cat9k-lni.17.06.01.SPA.pkg /temp//stage/cat9k-lni.17.06.01.SPA.pkg is Di
gitally Signed
Package cat9k-rpbase.17.06.01.SPA.pkg /temp//stage/cat9k-rpbase.17.06.01.SPA.pkg
is Digitally Signed
Package cat9k-sipbase.17.06.01.SPA.pkg /temp//stage/cat9k-sipbase.17.06.01.SPA.p
Package cat9k-sipspa.17.06.01.SPA.pkg /temp//stage/cat9k-sipspa.17.06.01.SPA.pkg
is Digitally Signed
Package cat9k-srdriver.17.06.01.SPA.pkg /temp//stage/cat9k-srdriver.17.06.01.SPA
Package cat9k-webui.17.06.01.SPA.pkg /temp//stage/cat9k-webui.17.06.01.SPA.pkg i
s Digitally Signed
Package cat9k-wlc.17.06.01.SPA.pkg /temp//stage/cat9k-wlc.17.06.01.SPA.pkg is Di
gitally Signed
Package /cat9k-rpboot.17.06.01.SPA.pkg /temp//rpboot/cat9k-rpboot.17.06.01.SPA.p
Preparing flash....
Flash filesystem unmounted successfully /dev/sdb3
Syncing device....
Emergency Install successful... Rebooting
Will reboot now
switch:
@Virendra Prajapati
Solution
switch: set
BOARDID=20569
BSI=0
MANUAL_BOOT=yes
RET_2_RCALTS=
SWITCH_NUMBER=2
TEMPLATE=access
VERSION_ID=V01
@Flavio Miranda
Thanks , now its working.
gnijs
Level 4
Level 4
Interesting. Does this mean that when a switch that was previously in 1+1 mode is joined to a stack that is in normal N+1 mode, does not boot or join the stack ?? I cannot find much information on cisco about interoperability of these two modes. What happens when an N+1 is added to a 1+1 stack ? i guess nothing, he will join as a member. But what happens when a previous 1+1 is added to an existing N+1 stack ??
