Multicast Issue on One Site
Patrick McHenry
Level 4
Level 4
Hi -
trying to resolve an issue with multicasting. We have a site that is working fine and we have a site that is not working. We are not sure if the issue is with the router or the host device trying to receive multicast traffic. The configurations are identical on both sites but, the only difference is that the site that isn't working has layer 2, 3750s hanging off the 3750 Core. The other working site only has a core switch.
Must I add any multicast config on the layer 2 switch?
Thank you
Jon Marshall
Patrick
You shouldn't need to add anything to the L2 switches (3750) as IGMP snooping is enabled by default. However you will need something to make the IGMP queries but i am assuming you have at least one L3 vlan interface in the site that isn't working with PIM enabled ?
Perhaps you could give us some more detail ie. what isn't working, what are your multicast configs etc.
Jon
Jon,
I've actually have ip pim passive configured on the VLAN interfaces of the Core switches. It seems to work on the one site though.
I've configured on switches:
ip multicast-routing distributed
interface GigabitEthernet1/0/47
description WN-1002X G0/0/1
no switchport
ip address 172.20.1.217 255.255.255.248
ip pim sparse-dense-mode
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust dscp
auto qos trust
spanning-tree portfast
spanning-tree bpduguard enable
end
On the routers:
Configured mroutes as it is going across an MPLS carrier
WN-1002-WAN1#sh run | i mroute
ip mroute 172.20.8.0 255.255.252.0 Tunnel105
ip mroute 10.255.255.1 255.255.255.255 Tunnel105
ip mroute 172.20.28.0 255.255.252.0 Tunnel105
ip mroute 172.30.60.0 255.255.252.0 Tunnel105
ip mroute 172.20.32.0 255.255.252.0 Tunnel105
ip pim rp-address 10.255.255.1
Patrick
Do you know whether the stream is actually making it into the site or is it not getting out of the first site ?
Have you ensured the TTL is set high enough for all the L3 hops.
Where is the RP in relation to the site that is not working ?
Jon
Don't have access to the equipment. Tuesday was my last day PC Connection. Starting new job Monday. Thanks for your help.
Pat
