Multicast Issues
adambaack
Frequent Visitor
Frequent Visitor
So I'm working on a project at work with Multicasting. This is the first time I've experienced multicasting so bear with me.
A friend at a different company said that it's a pretty simple process and you just turn on ip-multicasting on the main switch, put pim on the vlan you want enabled and make sure IGMP is on the edge switches. I've done all that and the latency goes to crap at my remote sites. I get huge delay, dropped packets, etc. I'm not seeing high processor usage and I'm just trying to find a way to find out what's going on. We have some weird setups so, maybe it's hard to do what we're doing?
Our Setup:
3 Main sites - 500MB Embarq Metro Ethernet that connect to each other through Cisco 6509s with encryption on the line.
Over 10 remote sites connected to our main site with 10MB Metro Ethernet also. These sites have Cisco 2821 routers.
So right now I'm only focusing on the three large sites (where the cameras will be) and turning pim on those vlans.
Site 1
VLAN 1
ip pim sparse-dense
VLAN 100 (vlan that connects to the main site)
ip pim sparse-dense
Site 2
VLAN 1
ip pim sparse-dense
VLAN 110
ip pim sparse-dense
Site 3
VLAN 100
ip pim sparse-dense
VLAN 110
ip pim sparse-dense
VLAN 4 (my pc lan I'm testing on)
ip pim sparse-dense
That's pretty much a very reduced look at our network, but hopefully it will help. Also, I forgot to mention that we're running EIGRP at all sites.
19 Replies 19
adambaack
Frequent Visitor
Frequent Visitor
Awesome! You've been a great help in my multicast journey.
So only having the access-list on your RP router permits or denies multicast traffic from routing between the routers?
No, for that I use ip multicast boundary "ACL NAME OR NUMBER"
Here is what mine looks like:
access-list 99 permit 239.255.46.14
access-list 99 permit 239.255.46.15
access-list 99 permit 239.255.46.12
access-list 99 permit 239.255.46.13
access-list 99 permit 239.255.46.11
access-list 99 permit 224.0.0.10
access-list 99 deny any
nterface GigabitEthernet1/12
ip address 10.33.94.105 255.255.255.252
ip pim sparse-dense-mode
ip multicast boundary 99
adambaack
Frequent Visitor
Frequent Visitor
Sorry for the continuous questions, but what would the access list associated to the RP be used for? Thanks!
In sparse-dense mode, the ACL is used to prevent routers from advertising auto-rp message to the mcast groups 224.0.1.39 and 224.0.1.40.
p.s. please rate if helpful.
adambaack
Frequent Visitor
Frequent Visitor
Great! Thanks for all the great help everyone. This was a great learning opportunity.
