Multicast not working
p.juarezponte
Level 4
Level 4
This is my first post so I apologize If I make some mistakes.
I would appreciate your help in this environment.
I attach a physical/logical diagram to clarify.
The "X" means 3, we have different systems which are the same but the second octect.
In this scenario, I have some different zones which have to work as source and as a receptor for multicast flows.
Everything works but RED Domain.
I mean, from a LAN on black domain (2960-XR)  and also connected to ESPINA network (asa 5545). Both as source or destination
I have a laptop connected to Vlan 30 (10.3.30.97) and another on WAN_1 (172.16.3.90).
I have to be able to receive and originate multicast traffic from some vlans on the red domain to a device on WAN_1.
I am using multicast hammer to make the tests, this is not in production yet (because of me).
All interfaces between devices are in pim sparse-mode.
Wan router is acting as RP for all of them.
Here is relevant config.
SW-RED-ISO10#
interface Vlan10
 description ATM_LAN1
 ip address 10.201.0.1 255.255.0.0
 ip pim sparse-mode
interface Vlan11
 description ATM_LAN2
 ip address 10.202.0.1 255.255.0.0
 ip pim sparse-mode
interface Vlan12
 description ATM_RED
 ip address 10.3.12.1 255.255.255.0
 ip pim sparse-mode
interface Vlan20
 description VCS_LAN
 ip address 10.3.20.1 255.255.255.0
 ip pim sparse-mode
interface Vlan30
 description SENSORS
 ip address 10.3.30.1 255.255.255.0
 ip pim sparse-mode
interface Vlan101
 description FW-RED
 ip address 172.16.3.14 255.255.255.248
 ip pim sparse-mode
ip pim rp-address 192.168.10.3
ip route 0.0.0.0 0.0.0.0 172.16.3.9
Router-WAN-3#
interface Loopback0
 description RP-Multicast
 ip address 192.168.10.3 255.255.255.255
 ip pim sparse-mode
interface Port-channel1
 description RED_TRANS_2
 ip address 172.16.3.41 255.255.255.248
 ip pim sparse-mode
 negotiation auto
interface GigabitEthernet0/0/2
 description External Agency
 ip address 172.16.3.89 255.255.255.248
 ip pim sparse-mode
 media-type rj45
 negotiation auto
ip route 10.3.0.0 255.255.0.0 172.16.3.46
ip route 172.16.3.0 255.255.255.0 172.16.3.46
And here is the output of my tshoot session.
It seems that pim is enabled correctly.
Router-WAN-3#sh ip pim inter
Address          Interface                Ver/   Nbr    Query  DR         DR
                                          Mode   Count  Intvl  Prior
192.168.10.3     Loopback0                v2/S   0      30     1          192.168.10.3
172.16.3.41      Port-channel1            v2/S   1      30     1          172.16.3.46
172.16.3.89      GigabitEthernet0/0/2     v2/S   0      30     1          172.16.3.89
10.10.200.3      Vlan200                  v2/S   1      30     1          10.10.200.3
SW-RED-ISO10#sh ip pim interface
10.201.0.1       Vlan10                   v2/S   0      30     1          10.201.0.1
10.202.0.1       Vlan11                   v2/S   0      30     1          10.202.0.1
10.3.12.1        Vlan12                   v2/S   0      30     1          0.0.0.0
10.3.20.1        Vlan20                   v2/S   0      30     1          10.3.20.1
10.3.30.1        Vlan30                   v2/S   1      30     1          10.3.30.2
172.16.3.14      Vlan101                  v2/S   1      30     1          172.16.3.14
SW-RED-ISO10#sh ip pim nei
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
      P - Proxy Capable, S - State Refresh Capable, G - GenID Capable
Neighbor          Interface                Uptime/Expires    Ver   DR
Address                                                            Prio/Mode
10.3.30.2         Vlan30                   01:04:21/00:01:22 v2    1 / DR S P G
172.16.3.9        Vlan101                  01:09:27/00:01:41 v2    1 / G
Router-WAN-3#sh ip pim neighbor
PIM Neighbor Table
      P - Proxy Capable, S - State Refresh Capable, G - GenID Capable,
      L - DR Load-balancing Capable
Address                                                            Prio/Mode
172.16.3.46       Port-channel1            00:46:14/00:01:42 v2    1 / DR S P G
10.10.200.1       Vlan200                  21:56:08/00:01:27 v2    1 / S P G
If I try to send traffic (pc on vlan 30 as server), it seems that register is successfull on SW-RED.
SW-RED-ISO10#sh ip mroute 239.4.52.44
(*, 239.4.52.44), 00:04:50/stopped, RP 192.168.10.3, flags: SP
  Incoming interface: Vlan101, RPF nbr 172.16.3.9
  Outgoing interface list: Null
(10.3.30.97, 239.4.52.44), 00:04:50/00:02:59, flags: PT
  Incoming interface: Vlan30, RPF nbr 0.0.0.0
On WAN router, I can't see ip source of MC flow.
Router-WAN-3#sh ip mroute 239.4.52.44
(*, 239.4.52.44), 00:04:03/00:02:53, RP 192.168.10.3, flags: SJC
  Incoming interface: Null, RPF nbr 0.0.0.0
    GigabitEthernet0/0/2, Forward/Sparse, 00:00:06/00:02:53
Then, I try to use PC wan as source, and PC on LAN 30 as a client.
I see it ok on WAN router, but I don't receive traffic on pc on lan 30.
(*, 239.4.52.44), 00:05:05/stopped, RP 192.168.10.3, flags: SJCF
    GigabitEthernet0/0/2, Forward/Sparse, 00:01:08/00:02:58
(172.16.3.90, 239.4.52.44), 00:00:55/00:02:04, flags: PFT
  Incoming interface: GigabitEthernet0/0/2, RPF nbr 0.0.0.0
As I said, we have this same scenario with other devices and other subnets and is working.
What I found out, is that I can't see SW RED sends PIM register to WAN router.
Here is the output of a working environment.
Router-WAN-1#debug ip pim 239.4.52.35
PIM debugging is on
Router-WAN-1#
2d04h: PIM(0): Check RP 192.168.10.1 into the (*, 239.4.52.35) entry
2d04h: PIM(0): Adding register decap tunnel (Tunnel1) as accepting interface of (*, 239.4.52.35).
2d04h: PIM(0): Building Triggered (*,G) Join / (S,G,RP-bit) Prune message for 239.4.52.35
Router-WAN-1#
2d04h: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.4.52.35
Router-WAN-1#
2d04h: PIM(0): Received v2 Register on Port-channel1 from 172.16.1.14
2d04h:      for 10.1.30.97, group 239.4.52.35
2d04h: PIM(0): Adding register decap tunnel (Tunnel1) as accepting interface of (10.1.30.97, 239.4.52.35).
2d04h: PIM(0): Insert (10.1.30.97,239.4.52.35) join in nbr 172.16.1.46's queue
2d04h: PIM(0): Building Join/Prune packet for nbr 172.16.1.46
2d04h: PIM(0):  Adding v2 (10.1.30.97/32, 239.4.52.35), S-bit Join
2d04h: PIM(0): Send v2 join/prune to 172.16.1.46 (Port-channel1)
2d04h: PIM(0): Removing register decap tunnel (Tunnel1) as accepting interface of (10.1.30.97, 239.4.52.35).
2d04h: PIM(0): Installing Port-channel1 as accepting interface for (10.1.30.97, 239.4.52.35).
2d04h: PIM(0): Send v2 join/prune to 172.16.1.46 (Port-channel1) (2 groups batched)
Router-WAN-1#
2d04h: PIM(0): Send v2 Register-Stop to 172.16.1.14 for 10.1.30.97, group 239.4.52.35
Router-WAN-1#
Router-WAN-1#
SW-RED-ISO10#
Jul 25 11:11:04.474: PIM(0): Check RP 192.168.10.1 into the (*, 239.4.52.35) entry
Jul 25 11:11:04.474: PIM(0): Building Triggered (*,G) Join / (S,G,RP-bit) Prune message for 239.4.52.35
Jul 25 11:11:04.474: PIM(0): Send v2 Register to 192.168.10.1 for 10.1.30.97, group 239.4.52.35
Jul 25 11:11:04.649: PIM(0): Received v2 Join/Prune on Vlan101 from 172.16.1.9, to us
Jul 25 11:11:04.652: PIM(0): Join-list: (10.1.30.97/32, 239.4.52.35), S-bit set
Jul 25 11:11:04.652: PIM(0): Add Vlan101/172.16.1.9 to (10.1.30.97, 239.4.52.35), Forward state, by PIM SG Join
Jul 25 11:11:04.963: PIM(0): Send v2 Register to 192.168.10.1 for 10.1.30.97, group 239.4.52.35
SW-RED-ISO10#
Jul 25 11:11:05.484: PIM(0): Send v2 Register to 192.168.10.1 for 10.1.30.97, group 239.4.52.35
Jul 25 11:11:05.488: PIM(0): Received v2 Register-Stop on Vlan101 from 192.168.10.1
Jul 25 11:11:05.488: PIM(0):   for source 10.1.30.97, group 239.4.52.35
Jul 25 11:11:05.488: PIM(0): Clear Registering flag to 192.168.10.1 for (10.1.30.97/32, 239.4.52.35)
SW-RED-ISO10#
Jul 25 11:12:02.859: PIM(0): Received v2 Join/Prune on Vlan101 from 172.16.1.9, to us
Jul 25 11:12:02.859: PIM(0): Join-list: (10.1.30.97/32, 239.4.52.35), S-bit set
Jul 25 11:12:02.859: PIM(0): Update Vlan101/172.16.1.9 to (10.1.30.97, 239.4.52.35), Forward state, by PIM SG Join
Jul 25 11:12:02.911: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.4.52.35
SW-RED-ISO10#
On the other hand, in this same scenario (except some octect), I only get this.
Router-WAN-3#
2d04h: PIM(0): Check RP 192.168.10.3 into the (*, 239.4.52.41) entry
2d04h: PIM(0): Adding register decap tunnel (Tunnel1) as accepting interface of (*, 239.4.52.41).
2d04h: PIM(0): Building Triggered (*,G) Join / (S,G,RP-bit) Prune message for 239.4.52.41
Router-WAN-3#
2d04h: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 239.4.52.41
Router-WAN-3#
SW-RED-ISO10#
Jul 25 11:55:59.524: PIM(0): Check RP 192.168.10.3 into the (*, 239.4.52.41) entry
Jul 25 11:55:59.524: PIM(0): Building Triggered (*,G) Join / (S,G,RP-bit) Prune message for 239.4.52.41
I am missing the PIM register from the SW to the router.
All intermediate firewalls have a permit any (I hope only temporary).
I'm sorry for all this big text, but I have no idea about the problem.
Any help would be so appreciated.
Thanks in advance.
I could finally find the problem, so I will share the solution, maybe this could help somebody in the future.
I could find out that multicast on vlan 30 worked if I unplugged the optical fibers which connected SW-RED-ISO10 with 20.
Actually, SW-RED-ISO20 was working as DR on vlan 30.
SW-RED-ISO20#sh run int vla 30
interface Vlan30
 description SENSORS
 ip address 10.3.30.2 255.255.255.0
 ip pim sparse-mode
 no ip route-cache
 no ip mroute-cache
end
SW-RED-ISO20 is just an access switch, and interface vlan 30 is the management interface, so I eliminated pim on that vlan.
Everything started working fine.
10.3.30.1        Vlan30                   v2/S   0      30     1          10.3.30.1
Thanks anyway for your help.
omz
Have you checked the software for any bugs?
Hello
SW-RED-ISO10
can you post the readout from these please, it may be you have a rpf failure.
sh ip pim interface count
mtrace 192.168.10.3
sh ip rpf 192.168.10.3
traceroute  192.168.10.3
Have you also tried sparse-dense pim and see if that works?
res
Paul
Kind Regards
Paul
Thanks for your help.
Here is the output.
SW-RED-ISO10#sh ip pim interface count
State: * - Fast Switched, D - Distributed Fast Switched
       H - Hardware Switching Enabled
Address          Interface                FS  Mpackets In/Out
10.201.0.1       Vlan10                   *   0/0
10.202.0.1       Vlan11                   *   0/0
10.3.12.1        Vlan12                   *   0/0
10.3.20.1        Vlan20                   *   123737/106
10.3.30.1        Vlan30                   *   0/0
172.16.3.14      Vlan101                  *   106/123737
SW-RED-ISO10#mtrace 192.168.10.3
Mtrace from 192.168.10.3 to 172.16.3.14 via RPF
From source (?) to destination (?)
Querying full reverse path... * switching to hop-by-hop:
 0  172.16.3.14
-1  172.16.3.14 ==> 172.16.3.14 PIM/Static  [default]
-1  192.168.10.3
SW-RED-ISO10#
 0  172.16.3.14
-1  192.168.10.3
SW-RED-ISO10#
SW-RED-ISO10#sh ip rpf 192.168.10.3
RPF information for ? (192.168.10.3)
  RPF interface: Vlan101
  RPF neighbor: ? (172.16.3.9)
  RPF route/mask: 0.0.0.0/0
  RPF type: unicast (static)
  Doing distance-preferred lookups across tables
  RPF topology: ipv4 multicast base, originated from ipv4 unicast base
SW-RED-ISO10#traceroute  192.168.10.3
Tracing the route to 192.168.10.3
VRF info: (vrf in name/id, vrf out name/id)
  1 172.16.3.38 3 msec 7 msec 4 msec
  2 172.16.3.41 10 msec *  0 msec
I have to say that today it worked, but I still don't know why, so it could fail again.
I think these were the steps.
I started a MC flow from vlan ESPINA (server connected to red firewall).
Then I could receive that flow on vlan 20 (client on the red switch).
Then all the others vlans could send and receive well.
I tried on vlans 30, 10, 11 and 12 and all were succesfull.
Does it has any sense to somebody?
I will try to make more tests, I begin my holidays and if I don't fix this tomorrow, will have to wait until September.
interface Vlan30
 description SENSORS
 ip pim sparse-mode
 no ip route-cache
 no ip mroute-cache
end
